logo
BB color code Shadow
BB color code Shadow 1.0.0
13
18
BB color code Shadow - Template Modifications
I share with you my bbcode color shadow
I use the addon Editor & BB Code Manager 1.2.1 Patch Level 1
1 - In your CP admin go to Custom BB codes and click on Import and select the xlm file that is being downloaded:
3 - Then fill in the fields:
Command ID: sha_1
Title: text-shadow
Icon: fas fa-palette
4 - Then drag the iconsin the bar below.
[IMG...
