Bit Flows Pro – Advanced Workflow Automation Plugin - Advanced Workflow Automation Plugin
Bit Flows is an Advanced, Super Fast, Drag & Drop automation plugin. Automation feels like Zapier inside WordPress.
Bit Flows isn’t limited to WordPress; it allows you to automate events outside of WordPress as well as process and send data to third-party platforms. This capability takes Bit Flows to the next level
For example, after a form submission or based on any event, the data can be processed and sent to over 150 platforms.
Bit...
