- Joined
- Nov 10, 2024
- Messages
- 1,175
- Reaction score
- 19
- Points
- 38
- Credits
- 16.00 Credits
BLOK - Xenforo style
BLOK is a clean geometric theme that is designed to be easy to use, easy to customize, and fast. Don’t like the geometric art? It can be disabled! Want a different background pattern? Easily switch between four existing presets. Would you rather use the default icon set, or one from another addon? No problem. Each element specific to BLOK can be changed, enabled, or disabled!
