Development mode - XenForo 2.3 - Development mode
Enable or disable development mode from the admin control panel.
Development mode must be enabled if you want to edit Cron entries, Template modifications or Master templates.
All phrases start with developmentmode_ for your convenience.
Setup:
Go to the add-on options page and enter the path to your config.php file.
FAQ:
Q: Do I have to be a super-admin to use this add-on?
A: Yes.
