Hide Resource Ratings - Hide resource ratings stars from the UI
XenForo allows you to prevent people from rating resources using simple permissions, however it does not hide the ratings stars from the UI.
This XF 2.x addon simply hides all reference to resource ratings from the UI - including the stars
It does not disable or prohibit people from using ratings - you should use the core permission settings for that.
You may also want to disable the Top resources widget - it's a bit pointless if you're not doing ratings.
Version 1.x of this addon is for...
